attaching sliding door to garage wall
Guest Peja43916
Guest Peja43916
Someone just gave me 2 3ft X 6ft sliding door panels and I want to mount them on my garage wall to use as my cutting board. For those of you who have done the same which I am sure many have, how do you go about mounting the slider onto the wall? A bracket of some sort, or should I just drill right through the frame and into the studs?
If they are still in the frame, then I'd drill right through the frame into the wall studs.
