PPF AVALANCHE HEADLIGHTS
Guest RCOOTE
Guest RCOOTE
I own an avalanche and just got a sample of ppf from my madico rep. wanted to try it out on the headlights. any tips or warnings for this vehicle. btw, first time playing with ppf.
thanx in advance
Guest RCOOTE
HAND CUTTING... I have a 1 ft x 2 ft sample so I wanted to try it out on something. THought I'd start with my headlights and go from there. If I like it I'll order a partial roll and see what what I can make from it..
any tips or advice are very welcome. pm's for those top secret tips.. do I shrink with heat?? I haven't yet done research on this topic.
Guest RCOOTE
Any slip needed. Just J&J mix??
no heat. you should have plenty of material. just cut to fit... apply... and cut out the lights ....just dont cut to hard.
:drevil
THANK YOU!!!! :rollin
Guest RCOOTE
I thought I'd tinker a bit first. I put it on my cell phone (twice).
The 1st time without slip, f-ked it right up. The second time with slip. Looks good but my cuts are terrible. I'm using a stainless blade. This stuff is not easy to cut nicely nor squeegee with a hard card. Any tips? Carbide blade for cutting perhaps??
    Tint My Ride
    rewiredtech.io
    2. 2
    3. 2
    4. 13
      Smallish bubbles 1.5 days after install; normal or cause for concern?
    5. 13
    6. 13
    7. 13
    8. 13
    9. 13
