avic avh-p4000
Guest Crackz
Guest Crackz
I figured it out hook up a toggle switch to the green wire and flip it back and forth 3 times works mint or if you feel like spending $ a tr7 to pulse it :rollin
Guest CajunTinter
Why the heck were you installing that thing in the middle of the night ???? :thumb :thumb :thumb :thumb
J/K dude..... Give me a shout when you run into shiatt like that !!! :thumb
Guest fredstinting
most pioneer avic unit that are made today cant be bypass with switch anymore but there is a silver stick on the bottom of the radio lift it and solder the connection together and then ground the green wire and it should work to by pass the system but if you have on with nav it will not do anything but allow you to programe addresses in while driving .
