09 R8 and 08 SuperLaggera
Guest Josh @ Proform
:tantrum
2009 GTS...same as the 08 I dont know............... :spit
:spit
what do figure TZ... start to finish with a bulk Por/turbo/SUV in hours with dry time..trim...wrap edge...and sealing edges? Just the bumper cover..I may try it your way next...Did you get the film to stick on the lower dull trim?
Bulking seems to take me about four times longer than using kits. It usually gives more coverage but sometimes I'll try for more than I should and end up having areas lift up once the customer has gone. I always end up thinking "So thats why the kit didn't go there...when will I learn?" Using kits also saves film especially if you can re-nest the layout. I've got door cups, door edge pieces, set of four wheel wells and a pair of mirrors pasted in the weeded areas on my Cayenne bumper pattern.
As far as sticking to that lower area, it will stick just not sure if it will stay. Use as little slip as possible. If you have any Xjel, that will probably work the best since its thicker and would act like "Poly-grip" on the textured surface.
    2. 7
    6. 11
    7. 11
