Bulk rear bumper
Guest XPEL Tim
You can do them without reliefs, you just need wider film so you can allow the film to lay naturally on the bumper. Otherwise you have to bend the film down as you approach the rear wheel arches causing excessive film at the bottom corners.
hei
itz higly impossible to do the rear bumper without relif cut.I done most cars no way .......I gotta give a cut in the lower part eventually no one can see that.
:thumb
the pick TZ has posted is the small GMC ''trial'' Denali. The full size Denali rear cornor sections are the same as the Escalade. A relief will save film.
I think a well thought out pattern may be an idea. Rear bumpers on top of the line trucks are the $$$ ticket. Most of my full installs include rear film coverage.
