MTX 3604 amp
Guest tint51
Guest fredstinting
I have this amp and it over heats when it is 80degrees out side..
In mornings has no problem..
Anyone know of a good external fan setup.
Thanks
sounds like your wired something wrong or the amps bad call mtx get it fixed should never over heat with the change of outside temp.
I play mine all day every day never over heat from the temp outside
Guest Drummmer69
Thanks
Few things to check, what size wiring going to amp??? I would step up to 4 gauge and make sure its grounded as close to the amp as posibble with 4 gauge also. Is there good air circulation around amp???? Not stuck in a panel somewhere?
Thanks
Yeah the wiring was smaller like 10.. and it was in a trunk.. But also I think it was a certain freq. cut out.. But have taken it out of the car sold the car so no it is in the garage but will do it that way once I put it in again..
Thanks,
Tint51
Guest Drummmer69
Thanks
Thanks,
Tint51
10 gauge wiring???? WOW thats the problem, im also assuming there is no cap inline with the wire??? If it were mine, I would run 4 gauge back to a 1 farad cap and call it good.
      Contravision
    3. 29
    6. 3
    8. 3
    9. 4
