How to use the marker
Guest citysign
Guest citysign
HI!
I'm a nweebie in vehicle tinting and a friend told me about a marker you could use if you got white spot on the window.
A) Is this true?
B) How should I use it?
Thanks!
Guest citysign
Kind of, seeing that I actually asked the question! I'm having a hard time believing that you had all the answeres when you started out. So if you have some constructiv critisism I will gladly listen to it otherwise try keeping it to yourself.
Guest Texstar
There called opaque paint pens, they are used to hide daylight.
City is you will use the search feature found at the top of the forum you will find alot of your questions answered and lots of good reading
Good luck :notwrthy
Guest citysign
Good luck :notwrthy
Thanks Pit Stop!
I'll take a look right away!
there is not any proper way to FIX tint for scratches or nicks except to replace the tint.
a great number of us here and in the industry did NOT have information handed to us. We learned all the secrets the hard way of just doing it......
use the search feature and if you can't find your answer from there then ask questions such as these.
Guest walestint
ok here you go then
constructiv criticism
dont use the pen to hide contamination, black electrical tape on the outside will do or just tint it properly
    2. 7
    6. 11
    7. 11
