Thermal Fracture
On dual pane windows with film applied, is it possible for a thermal fracture to occur on the interior pane and not the exterior pain? Also does a thermal fracture have to "fork" to be considered a thermal fracture or can it just be a single crack? Just curious as I have a customer requesting me to verify the below crack to see if it falls under the film manufacturer's warranty. I know it is ultimately up to the film manufacturer to make the decision, but I dont think it looks like a thermal fracture. One it is a very light film, no shading, and there is a shelf below the interior bottom pane where I noticed the customer had place objects on it and something could of fell over hitting the interior glass causing the crack, but we all know a customer isnt going to fess up it that is the case.
It is possible that the glass had a chip or flaw of some sort on the edge, where you couldn't see it, that may have stressed the glass more after the film install...
Even with a lighter film, the absorption could have caused it to expand and contract more than it used to...
Also, those blinds look a little close to the window as well..
I am by no means a total expert on the subject, but if I had to guess, that would be my consensus... :thumb...
Good luck..
Let me know what you end up having to do... :thumb
I've never had an external dual pane crack, (yet) had my share of internal ones though :thumb Most of them have been single line fractures like that one. In almost all cases it has been because of a nick or chip in the edge as shady pointed out. Blinds are close, when there closed they surely add to the stress on the glass
straight out would not be considered "normal" for a thermal stress crack. Out an inch or so and then off at a sharp angle is what I have been told.....
Also never heard of it causing any problems on the outer pane....
Guest Bulldog
Thermal fractures always "meander" throught the glass. Straight line cracks indicated a faw in the edge of the glass. After seeing your picture and the light film you applied, I would say no way the film caused it.
Damn, they require you to send pictures of the crack? I have no doubt that the glass had a previous small crack and the film helped it along, but if it were me, I would tell the customer that you will replace the window. Then I would send in a claim to the manuf for the glass breakage warr to get reimbursed. Whether or not it is a result of the film doesnt matter to the customer, they want it fixed. They will feel all warm and fuzzy inside if you fix the problem without hesitation in a prompt manner, and you will have a customer for life. It will be problem that the customer will tell others about, but in a good way. :poke
      Hiring A Flat Glass Installer
    2. 3
      OG tinter
    3. 4
      Peanut Killer
    4. 4
      Peanut Killer
    5. 4
      Peanut Killer
    6. 3
      OG tinter
    7. 3
      OG tinter
    8. 4
      Peanut Killer
    9. 0
