TintDude Posted November 16, 2008 Report Share Posted November 16, 2008 #1 By "StreetsAheadWindowTinting" Tin Can Blade Disposal I made a blade disposal canister out of two canned fruit tins.Sanded the lip of both tins. Soldered them together. Cut a slot in the end of one can with Dremel and Disc Cutter bit. Presto, the cheapest safest blade disposal canister! #2 By "TintJunkie" Wax technique Instead of using baby powder, use wax. I use some "shaping spray" from my distributor. Enprodistributing.com.Spray it on, or if not in a can, wipe a small amount on the back glass. Let haze up a little. Do your "H" with a damp paper towel to anchor the film and shape from the middle up/down. You can hold a heat gun on the film for a long time with wax before it starts to burn the film. Anyone else do em this way? At least for more curved back glass's?? Link to comment Share on other sites More sharing options...
tintman Pa Posted November 16, 2008 Report Share Posted November 16, 2008 gotta try it...if it is as good as the maddog soap method...oh happy day.... and the tin can idea is good to...but wax on wax off.....kinda catchy Link to comment Share on other sites More sharing options...
JRock10 Posted November 18, 2008 Report Share Posted November 18, 2008 I'm using an old Smart Water bottle for blade disposal. Pretty thick, and I can cap it when done. Link to comment Share on other sites More sharing options...
Guest tintmanlibby Posted November 18, 2008 Report Share Posted November 18, 2008 wax tech. sound's alot like the soap tech. ,but messyer Link to comment Share on other sites More sharing options...
Guest jlewark Posted November 19, 2008 Report Share Posted November 19, 2008 You can also cut small slit into your old olfa container to break your blades fits into pouch Link to comment Share on other sites More sharing options...
tuttle Posted November 19, 2008 Report Share Posted November 19, 2008 You can also cut small slit into your old olfa container to break your blades fits into pouch I've had to maney snake bites!! poping blades in my pouch. great little container Link to comment Share on other sites More sharing options...
