for dry shrinkers
Guest rondy_
After cleaning the window with soapy water solution and rubbing soap on a damp towel (as usual). Re-mist the back window with the soapy water solution and wipe it with the towel.
This will create a more even layer of soap on the window.
When you get to do your reverse roll. After wetting the film. Spray also on the outside part of the liner. This will ensure a good reverse roll and as tight as you want. It will also make it easier to reverse roll during the installation, making the liner stick better to the outside part of the film.
By outside I mean the side that is not in contact the the film's adhesive.
I hope you get my words.
:bingo
      Peanut Killer
    2. 3
      Peanut Killer
      OG tinter
    4. 1
      OG tinter
      Peanut Killer
    6. 0
    7. 6
      Tack Solution When Vinyl won't lay flat
    8. 6
    9. 6
    10. 3
      Peanut Killer
