Help! Keyless entry on Camry
Guest Foogoo
I have a '98 Toyota Camry with remote lock/unlock that beeps when you operate it and it has one of those flashing red lights on the dash. Today I was replacing the radio, which was easy enough. The only cables I touched were the two headunit cables and the antenna cable. Something was wrong w/ the new stereo so I disconnected it, reconnected the old stereo, and put everything back. Easy enough right? But now the keyless entry does not beep and the red light stays lit. The doors still lock/unlock though. What could I have done wrong in the process? Where should I check? Thanks a lot.
    Tint My Ride
    rewiredtech.io
    2. 2
    3. 2
    4. 13
      Smallish bubbles 1.5 days after install; normal or cause for concern?
    5. 13
    6. 13
    7. 13
    8. 13
    9. 13
