dgmt321 Posted January 29, 2009 Report Share Posted January 29, 2009 Sorry I have a newbie question to ask you guys. I been seeing alot of videos people use a razor blade to clean window? I am kinda new to tinting(3-4 month) and I've always been cleaning the inside of my window with a cloth and had no trouble removing the goo and stickers. I never tried using a razor blade tho, Is there a huge advantage using a razor blade to clean window? I am kinda scared scraping my window with a sharp razor blade. Any thoughts or advice? Link to comment Share on other sites More sharing options...
Tint Artist Posted January 29, 2009 Report Share Posted January 29, 2009 It's good to razor a window to get off all kind of different things that you might not see like some adhesive from stickers or whatever! I use the white scrubbie pads on windows after I razor them just to make sure! Just remember in this trade you can never over clean! Link to comment Share on other sites More sharing options...
micro-edge Posted January 29, 2009 Report Share Posted January 29, 2009 To save you an OHSHIT moment don't use a razor on rear windows with defrosters. Common sense I know but who knows what some ppl may do, razor on doors is no problem though. Link to comment Share on other sites More sharing options...
TintJunkie Posted January 29, 2009 Report Share Posted January 29, 2009 Right on TA! Clean 2,3,4,5....times, lay the film once. I use razors as well (I think we all do). Sometimes when there is a smudge of grease or something on the window, a blade is the fastest easiest way to remove it. Wiping it only smears it. Link to comment Share on other sites More sharing options...
Guest scottydosnntkno Posted January 29, 2009 Report Share Posted January 29, 2009 don't be afraid to use a razor on the side windows, or any window without defrosters. honestly, theres been a lot of times where im not paying attention and the razor blade flips up on end and it still doesnt scratch the window. as long as you have lubrication on the window, and keep the blade on an angle you will be fine. it gets off any little microscopic specs that are embedded in the glass that you couldn't see with your eye, and just a cloth wont get off Link to comment Share on other sites More sharing options...
Slick Posted January 29, 2009 Report Share Posted January 29, 2009 don't be afraid to use a razor on the side windows, or any window without defrosters. honestly, theres been a lot of times where im not paying attention and the razor blade flips up on end and it still doesnt scratch the window. as long as you have lubrication on the window, and keep the blade on an angle you will be fine. it gets off any little microscopic specs that are embedded in the glass that you couldn't see with your eye, and just a cloth wont get off tell that to this guy Scratched the Glass Link to comment Share on other sites More sharing options...
ljr1977 Posted January 29, 2009 Report Share Posted January 29, 2009 im sure everone does, I know I do! you always want to go one direction with the blade never draging it back across the glass.....this one is hard to exsplain in words "HELP-somebody exsplain it better" Link to comment Share on other sites More sharing options...
VIP tint + glass Posted January 30, 2009 Report Share Posted January 30, 2009 above poster means only go in the direction of the blade, dont drag it backwards. blades here. and when you blade bordered glass, blade the inside first then the edges last. going over the black border can dull the blade. and a dull blade can scratch the glass very easy. UVS glass is very soft and scratches easily (quarterglass on TC's and G35 coupes). also be careful on ford and dodge rear flat glasses. Link to comment Share on other sites More sharing options...
Guest absolutetinting Posted January 30, 2009 Report Share Posted January 30, 2009 Sorry I have a newbie question to ask you guys. I been seeing alot of videos people use a razor blade to clean window? I am kinda new to tinting(3-4 month) and I've always been cleaning the inside of my window with a cloth and had no trouble removing the goo and stickers. I never tried using a razor blade tho, Is there a huge advantage using a razor blade to clean window? I am kinda scared scraping my window with a sharp razor blade. Any thoughts or advice? omg! Link to comment Share on other sites More sharing options...
Guest juns Posted June 11, 2009 Report Share Posted June 11, 2009 and make sure the blades are stainless steel. Link to comment Share on other sites More sharing options...
