merc s320 2003
Guest Hashy
should be easy as unbolting the glass and once its unbolted slide the front of the glass down as the rear of the glass needs to go up.(passenger front)rotate the glass 15 degrees(if your on the passenger sidefront) go point would be the shorter side has to go and the longer side has to go up with it midway...
some cars have rivets that have to be drilled and replaced with 1/4 twenty bolts and nuts w? lock washers..if you have a bigg daddy pop rivet gun you replace them with rivets
you take the glass out to lock it to the regulator if you have dow-corney use it on the egde...this keeps it from being broke and then lifted out the car....
I did my old mustang in 7mil 35%
