defender sliders
Guest dagz
Anyone know how to remove the sliders on the newer models? Cheers
Just send it to your competitor :spit ,drilling frame out is not an option as you will slide across the paint with the drill and they hold so much crap around the frame clean install is very difficult.
Have you got the standard green mould on the felts :rollin Enjoy
it's a 2005 model, so no mould yet! I've drilled the rivits out the old ones, not really a problem, it just takes a lot of time. but I can't even see any rivits on this one, can't see how you take them out...
From memory you have to find the small ally tac welds on the two sides and carefully cut with fine hacksaw and seperate the frame without warping in anyway.
As I said nasty job but well done for having the patience to remove those rivets and not scratching the paint,you could become a specialist in these agricultural beasts :rollin
