portable inflatable garage
I really need to by a plotter so this is the lowest I will go $1600 if interested call me kevin 843-367-9657 and if u pick it up I will even throw in a heater so you can still tint when its 40 degrees outside.The heater will bring it up to 65-70 degrees inside
fastshelter model 850 measures 20ft long 16.5 feet wide 8.5 ft high.Sets up in 5 minutes packs up in a 3 ft by 3ft bag in less then 8 minutes.Go to www.fastshelter.com to check it out.I live in Charleston I really need to by a plotter so this is the lowest I will go $1600 if interested call me kevin 843-367-9657 and if u pick it up I will even throw in a heater so you can still tint when its 40 degrees outside.The heater will bring it up to 65-70 degrees inside
