PS adhesive and reverse rolling
get yourself a lightweight metal rod that's maybe 60 inches wide and big around as a nickel. roll the film onto it and reverse roll it down the glass. much easier for the inexperienced. and use more soap than you think you'll need.
I was asked by a glass guy to tint very hard to reach closit window. went to see the job. 40x100, the film was frost with the only access to the glass on the top and bottom of the window. cut the film to fit on my slitter, rolled it on to the pipe I had cut to 36". used my triumph and unger's on broom sticks to clean the window, did the window while the contractor watched (didnt have a choice). never heard another word. drive by the condo and the whole run is tinted. guess he needed a lesson. I dont use the pipe very often but it sure helps in a sticky situation. ps the heavier the better.
I'd bet there are a lot more flaws in the ones he did than the one you did. Expecially with frost film. At least you can get some comfort from that. :bingo
    2. 7
    6. 11
    7. 11
