Cleaning glue from BG
Guest justincredible
Guest scottydosnntkno
I just use a mix of my normal JJ solution with some amonia and alcohol, spray on, let sit for 5 mins, spray again, let sit one more min, then use 0000 and scrub the whole window, usually takes <5 mins of scrubbing for a whole backglass. then use a bulldozer scrubber for the bottom edge. Then clean, squeegee, and retint
If you have adhesive remaining on the glass after you've steamed it, sweat it, heat it or whatever method you used...just spray some ammonia on the adhesive and let it sit until the odor dissipate and rub the remaining residue off with #0000 steel wool or white scrubbie. Works like a charm :beer
    2. 7
    6. 11
    7. 11
