audi tt
Guest fimmo
this car has already been covered but here is a small but very handy tip!!! if your like me and prefer to pull the door panels the tt has the best door panels in the world!! on the handle there is a small cap about 1.5 inch in diameter twist this off (it's a twist lock cap) inside there is a bolt to remove,remove it then just lift the panel off!!!! easiest door in the world. I know it's a frameless door but I'm a bit edgy when you push the glass forward to open up a gap between the glass and the rubber especially on a door that is sooooo easy to strip! :rollin
    Tint My Ride
    rewiredtech.io
    2. 2
    3. 2
    4. 13
      Smallish bubbles 1.5 days after install; normal or cause for concern?
    5. 13
    6. 13
    7. 13
    8. 13
    9. 13
