Cutting the trash bag
Guest scottydosnntkno
I have been using tint off . I will try the soap and water only next time. I thought the amonia broke down the glue quicker .
amonia breaks down the glue, but that isn't always good. like if you peel the film then spray n scrub(like I do a lot) it turns the glue into a sticky gunk that doesn't like to get wiped up very easily. similar with sweating, it will loosen the glue yes, but when you peel off the film it will leave a lot on the window since its a sticky pulp by then. water/soap on the other hand rehydrates the glue, but when you peel it off its similar to tacked up fresh film, where its tough to pull off, but doesn't leave any glue behind :spit
  • Replies 20
