Guest jain1980 Posted July 15, 2009 Report Share Posted July 15, 2009 What PPF would folks here recommend with the 'least amount of orange peel' and a good adhesive (so that it holds up longer) ? Link to comment Share on other sites More sharing options...
Bababooey Posted July 16, 2009 Report Share Posted July 16, 2009 Venture Ultra or Xpel Premium. Both are very flat and the only two I would trust. Llumar's got some flat film but it's garbage. Link to comment Share on other sites More sharing options...
blade Posted July 16, 2009 Report Share Posted July 16, 2009 venture ultra Link to comment Share on other sites More sharing options...
htp autoworks Posted July 17, 2009 Report Share Posted July 17, 2009 I have tried just about every film on the market. I found that ClearMask AR (3M Aerospace grade film) is the best all around film. Same appearance as Venture Ultra but the adhesive is much better and it cuts your install time down considerably. It is also much more durable than Ultra and does not scuff easily. Great overall film. Give it a shot. ClearMask.com Link to comment Share on other sites More sharing options...
Guest jain1980 Posted July 17, 2009 Report Share Posted July 17, 2009 I have tried just about every film on the market. I found that ClearMask AR (3M Aerospace grade film) is the best all around film. Same appearance as Venture Ultra but the adhesive is much better and it cuts your install time down considerably. It is also much more durable than Ultra and does not scuff easily. Great overall film. Give it a shot. ClearMask.com Yes..I was about to ask on this film..Heard a lot off late abt this film. How does this film compare to VS Ultra in terms of pricing ? Where can I buy some samples of clearmask AR and if I want to buy 24" bulk rolls, where ? Do they offer international shipping to HongKong ? Thnx Link to comment Share on other sites More sharing options...
Speed Posted July 17, 2009 Report Share Posted July 17, 2009 The Aerospace film is intended for airplanes, and they don't care if the paint comes off when its removed. I'd stick with something that's designed for automotive applications. Link to comment Share on other sites More sharing options...
alberts316 Posted July 17, 2009 Report Share Posted July 17, 2009 The Aerospace film is intended for airplanes, and they don't care if the paint comes off when its removed. I'd stick with something that's designed for automotive applications. Good call Link to comment Share on other sites More sharing options...
htp autoworks Posted August 21, 2009 Report Share Posted August 21, 2009 The Aerospace film is intended for airplanes, and they don't care if the paint comes off when its removed. I'd stick with something that's designed for automotive applications. Actually this is not a "good call". The adhesive I have found is stronger the Venture Ultra but not as strong as 3M is. It is MUCH easier to remove than 3M... and after 6 years of using it now I have yet to see of ever hear of film lifting paint. I have seen 3M lift a few times though... and had times where the film came off in little pieces instead of a sheet. ClearMask does stand behind the warranty as well and I have spoken with Jim about paint lifting issues and he does cover it if it happens. Link to comment Share on other sites More sharing options...
alberts316 Posted August 21, 2009 Report Share Posted August 21, 2009 The Aerospace film is intended for airplanes, and they don't care if the paint comes off when its removed. I'd stick with something that's designed for automotive applications. Actually this is not a "good call". The adhesive I have found is stronger the Venture Ultra but not as strong as 3M is. It is MUCH easier to remove than 3M... and after 6 years of using it now I have yet to see of ever hear of film lifting paint. I have seen 3M lift a few times though... and had times where the film came off in little pieces instead of a sheet. ClearMask does stand behind the warranty as well and I have spoken with Jim about paint lifting issues and he does cover it if it happens. I personally have only seen paint lift/peel if its not OEM paint and a sh!tty respray. How about you keep using what your using and I will keep using what I am using Link to comment Share on other sites More sharing options...
Guest Suncs Posted August 21, 2009 Report Share Posted August 21, 2009 I do mixture of both for full hoods I go with Durashield. And for the standard stuff I use 3M Link to comment Share on other sites More sharing options...
