DGI Omega Series OM-150 + Dell Latitude Laptop - Model PPO1L
Solar Solutions NY
3 Yrs Old
With stand
1530mm (60") cuttable width
• High Speed for High Productivity
• 500 grams of Cutting Force
• Guaranteed tracking
• HP-GL Compatibility and Easy Control Panel
32 bit CPU and highly advanced servo control technology enable DGI Omega Series to cut straight lines and arcs as fast as 80CM/sec(31.5i).500 Grams of Cutting Force DGI Cutting Plotter series can cut various materials from normal vinyl to rubber mask clearly and accurately. The maximum cutting pressure of 500 grams and fine pressure adjustment allow cutting of hard materials such as high intensive reflective and fluorescent sheets, thick materials like sandblast mask.HP-GL Compatibility and Easy Control PanelThe DGI Cutting Plotter Omega Series work most popular sign making software because their SP-GL language is compatible with the industry standard HP-GL. And the backlit LCD panel display can easily can be seen in dark areas
Serious Inquiry Only
email: info@solarsolutionsny.com
Plotter is in New York
    2. 7
    6. 11
    7. 11
