help with a roland cx-400
Guest Sarah
the problem is with the default speed between patterns? the cut speed is fine while cutting a pattern, but when I finishes one pattern it then goes way to fast to get to the next pattern. is there a setting or driver that will keep it at the same speed after its done cutting a pattern and going to the next?
ok so last night I was told that roland calls it off-set speed...I have now fixed the issue and gives a big thanks to mr.turner @ performance films "you are the man"
thanks also to slick for the sight, I needed other info that the sight had. it realy helped me out also.
