Help with my mk2
Guest mj10
  • Replies 45
Guest tint325i
couple of torx screws either end, and I think its 2 (but it could be 4!!!) 10mm nuts along the length of it, they have little plastic covers over them, then lift spoiler, it still has 2 plastic clips holding it on but it pops up easy enough, then disconnect brakelight and washer, dead easy
I do this with mgzr and civic type-r also. probably a few others I cant remember (saxo and c2 screwed in thru glass so must come off)
Guest polski sklep in UK
Are you wishing to be a window tinter or just get a cheap install on your own car then???? The latter I think?,
Correct, But as I'm going along I'm learning how to do It. Least then If any mates need a hand I can offer to help them out. However, If anyone can do me a pre shrunk back winda that will save me having the ball ache all over again.
I send you pre-shrunk rear for 50pounds
