CDF Adhesive
Guest auricwealth
Guest auricwealth
Pardon my ignorance, this is really a novice queston.
Most architectural films in the market comes with detack CDF Adhesive which can be more long lasting & optically clearer after curing. A little bit of heat will adhere them to the glass. Is there any way that we can make such installation during winter??? hairdryer??? :twocents
Thanks guys!
~ ~ ~ "She didn't believe in angels until she fell in love with one." ~ ~ ~
Guest auricwealth
hmmmmmmm.gif You may have an issue with cdf on a skylight with no sun out that day but other than that.....tint away, may have to hard card it a bit more but should be no problems..
really? even in freezing temperatures? WOW! thanks pal.
Guest auricwealth
Single pane = 5-7 nights of above 22 degrees while inside building temp stays 65-70
Dual pane = 10 degrees or above fahrenheit
Thanks!!! Delighted to have such specific info.
:bingo
:lol2 You may have an issue with cdf on a skylight with no sun out that day but other than that.....tint away, may have to hard card it a bit more but should be no problems..
Oh, I was meaning if you were a professional then winter installation should be no problem pal :poke
Guest auricwealth
We use DA every day. It is cold up here 4-6 months a year. If you are filming IG you should have no problems at all. If you film single pane glass that is a different story.
doesn't activate the adhesion right???
thanks
    5. 4,168
      What did you tint today?
    6. 4
    8. 4
