Printing on corrugated plastic.
Guest h0wld0g
Guest h0wld0g
How do you print on corrugated plastic like standard 18"x 24" sheets for like political signs and real estate signs and such I'm doing some real estate signs for a company and I'm going to just do it with vinyl but in the future I'd like to print it so what does it take to do it.... as in screen print or what help thanks
Guest scottydosnntkno
screen print, flat bed printer, or print on vinyl........
:? if you're wanting a full color print, the only solution is to print onto vinyl, like a car wrap but no laminate(most signs don't need to last for 2+years).
if your just doing simple 1,2,3,4 color designs, the cheapest and easiest will be to just use cut vinyl(assuming you have a plotter)
Screen printing will work if you have say a hundred of one sign to make
Guest h0wld0g
yes I have a plotter I was just curious as I'm doing realtor signs for this company and the old signs that the other sign company did printed them and not vinyl so I was curious how to do it... but I'll probably end up just doing vinyl on them thanks
    5. 4,168
      What did you tint today?
    6. 4
    8. 4
