auto electrics
Guest tint325i
Guest tint325i
my 530d is drawing 0.6A out of battery when idle, this flattens battery within a few days, ive tried unplugging phone, stereo and anything else I can think of but drain is still there, ive even pulled every fuse out 1 by 1 but cant find anything, had it into local auto sparky bit no joy there either, any ideas guys???
Guest naughtydog
Is their a fusebox in the boot on yours? That sounds like a mnajor drain?
Maybe a ground problem?
Guest tint325i
yeh .6A is loads, there is a fusebox in boot next to battery, have tried pulling fuses 1 by 1 but it only drops on 1 fuse by about 0.06A (which is about what the current draw should be for clock etc) but I have no idea where the other .5A is going, only thing I have in the car that shouldnt be there is a handsfree, have unplugged this along with headunit and autochanger, have even unplugged alternator incase of diode failure (have seen that cause a drain before) does my head in that I cant leave car from one weekend to the next without it going flat, it goes flat in about 2 or 3 days
Guest tint325i
Are you sure your battery doesn't have a dead cell?
I dont think so but will check it 2moro with a heavy discharger, why would a dead cell make the car daw 0.6A? thats a massive drain, that juice has to be going somewhere! the battery is brand new but will need replaced soon enough if it keeps geeting flattened as its not a deep cycle battery (usually used in caravans or boats)
A draw of that size is typically a light bulb... glove box light, under hood light, trunk light, etc not turning off when it should
When that fails I typically go unplug the alternator... sound like you have gone through the correct steps...
:eyebrows
Guest tint325i
yeh bulbs was my first thought, I have actually removed the glovebox light, and both boot/trunk lights, the rest of the interior lights are easily visible so I know they are off, might just torch it!!! lol
    2. 5
    3. 5
    4. 5
    5. 5
    6. 5
    7. 0
      INDIANAPOLIS, INDIANA NOW HIRING FOR AUTOMOTIVE WINDOW TINTER
    8. 0
      Window Tint Training For Groups Or Individuals
    9. 3
      Tinting is annoying, i need help
    10. 0
      3M Experienced Flat Glass Installers Needed In Sunny West Central Florida
