TSER vs IRR
Guest swong2046
Guest vclimber
I'm trying to compare the specs from diferrent tinted shops but most of them has higher IRR (~90%+) but lower TSER (~60%+). Need to check how to calculate the TSER as it is not correct that I calculated like this:
TSER%= 44% x VLR%+ 3% x UVR%+ 53% xIRR%
Any advice? as I dont want to be con by those supplier
100-(sc*.87)
Do not compare IRR it is not a total performance measurement.
The formula you ask to find TSER is:
TSER = 0.43*VLR + 0.03*%UV + 0.54*IRR
we already know the TSER but would need to verify IRR from given TSER
reversing and figuring to find the IRR from the given TSER:
(TSER - (0.43*VLR + 0.03*UV)) / .54
so if the TSER is 48 and the VLR is 9 and th UV is 99, then:
(48 - (0.43*9 + 0.03*99)) / .54
=76.2222 IRR
just copy past this line into google search with your spec numbers replacing the TSER, VLR and UV:
(TSER - (0.44*VLR + 0.03*UV)) / .54
The resulting IRR number seems a little high, which makes me wonder how the manufacturers figure it
    3. 6
    5. 11
    6. 11
    7. 6
