Dj Kustoms Posted April 4, 2010 Report Share Posted April 4, 2010 How do you guys go about shrinking more curved back glass's..did a 98 monte and just doing the back glass brought out huge fingures that couldn't be taken out perfectly.any tips.I just tried the the normally h shrink Click here to view the article Link to comment
Guest tintjam65 Posted April 4, 2010 Report Share Posted April 4, 2010 Invisi-seam at defrost. Takes me less time to 2-piece shrink, seam and install than to shrink one-piece on hard back glass. Link to comment
Guest 515tinter Posted April 5, 2010 Report Share Posted April 5, 2010 Invisi-seam at defrost. Takes me less time to 2-piece shrink, seam and install than to shrink one-piece on hard back glass. or just take your time and get it in one piece did you do the monte wet or dry? Link to comment
Dj Kustoms Posted April 6, 2010 Author Report Share Posted April 6, 2010 I dry shrunk it.got more harder with the h pattern so I just tried the middle anchor.but when I got towards the middle on the top and bottom I would get one hugggggggeeeeeee fingure that would come out Link to comment
VIP tint + glass Posted April 6, 2010 Report Share Posted April 6, 2010 instead of workin toward the middle, try working the whole section down at the same time. im sure you work the window in quarters, so get the whole quarter down gradually. sound like your shrinkin the film all the way to the end and working toward the middle. Link to comment
Guest scottydosnntkno Posted April 6, 2010 Report Share Posted April 6, 2010 instead of workin toward the middle, try working the whole section down at the same time. im sure you work the window in quarters, so get the whole quarter down gradually. sound like your shrinkin the film all the way to the end and working toward the middle. :smoker I don't remember anything that hard about that window. just do your H, and work from the middle side to side all the way to the bottom/top of the glass without stopping. don't worry if you don't get all the shrink the first time, because you can always come back once it cools. This will also pull the excess from the other side towards the middle, so once you move over to that side it'll be a lot easier. Link to comment
Dj Kustoms Posted April 6, 2010 Author Report Share Posted April 6, 2010 ya what I was doing was just a normal middle anchor and then I would start in the middle and go little by little and eventually end up in the middle.weird how you guys knew that hahah Link to comment
