dgmt321 Posted April 10, 2010 Report Share Posted April 10, 2010 I know this is probably a dumb question but is there anything important I need to know about tinting over factory tinted glass? I want to know ahead of times to prevent any stupid mistakes. thanks. Link to comment Share on other sites More sharing options...
Guest scottydosnntkno Posted April 10, 2010 Report Share Posted April 10, 2010 I know this is probably a dumb question but is there anything important I need to know about tinting over factory tinted glass? I want to know ahead of times to prevent any stupid mistakes. thanks. Link to comment Share on other sites More sharing options...
Guest Scottsfire Posted April 10, 2010 Report Share Posted April 10, 2010 Keeping in mind that I'm a rookie new to the industry, but I feel fairly certain that the pigment in factory tinted glass is inside, therefore making it no different than tinting normal untinted automotive glass. You may have to calculate in the % of the factory tint to what the % of the film your installing, but other than that should be fairly simple. Hope this helps, Link to comment Share on other sites More sharing options...
Guest WFWB Posted April 10, 2010 Report Share Posted April 10, 2010 no Link to comment Share on other sites More sharing options...
Guest tintjam65 Posted April 10, 2010 Report Share Posted April 10, 2010 Yes Only with those reflective coated auto glass types like the Lexus R330 or the reflective glass used in some Ford and Nissan SUV's Over time film adhesive destroys the protective clear coat used to protect the metal deposition which eventually leads to destroying the metal coating And if you ever do remove film from this type glass hope it comes off easy but any way it does come off the glass surface scratches easily taking off the adhesive Link to comment Share on other sites More sharing options...
Guest Scottsfire Posted April 10, 2010 Report Share Posted April 10, 2010 TintJams, I stand corrected and a little more educated. Thanks for the heads up on these veh. Link to comment Share on other sites More sharing options...
VIP tint + glass Posted April 10, 2010 Report Share Posted April 10, 2010 YesOnly with those reflective coated auto glass types like the Lexus R330 or the reflective glass used in some Ford and Nissan SUV's Over time film adhesive destroys the protective clear coat used to protect the metal deposition which eventually leads to destroying the metal coating And if you ever do remove film from this type glass hope it comes off easy but any way it does come off the glass surface scratches easily taking off the adhesive we have a winner, also watch out on some sunroofs. blade lightly or just scrubbie them. the tint on these is like a coating instead of a colored glass on r+r's I steam em Link to comment Share on other sites More sharing options...
micro-edge Posted April 10, 2010 Report Share Posted April 10, 2010 YesOnly with those reflective coated auto glass types like the Lexus R330 or the reflective glass used in some Ford and Nissan SUV's Over time film adhesive destroys the protective clear coat used to protect the metal deposition which eventually leads to destroying the metal coating And if you ever do remove film from this type glass hope it comes off easy but any way it does come off the glass surface scratches easily taking off the adhesive Good call,those will scratch easily if you're not careful Link to comment Share on other sites More sharing options...
Guest scottydosnntkno Posted April 10, 2010 Report Share Posted April 10, 2010 I've never tinted over that crappy lexus tint or the reflective for shiat Link to comment Share on other sites More sharing options...
Guest WFWB Posted April 10, 2010 Report Share Posted April 10, 2010 Mybad I should have read it closer I thought we were talking about pretinted flat glass! Link to comment Share on other sites More sharing options...
