2010 A6
Guest tint325i
Guest tint325i
for those who havent done one yet- the brake light looks like the A4 one but doesnt fix on in the same way, the A4 ones just pull off then slide back on with a little force, the A6 is like a bmw with the 2 clips that slide sideways, panel at top of screen comes off easily exposing clips
trim is also butted hard up to matrix on the 1/4s, stripping them out give you access to matrix for heating if you need to and dramatically reduces risk of contamination from trim fluff
Guest naughtydog
Thanks - are you heating the matrix still these days?
Must be a jock thing :thumb
Guest tint325i
depends on the film nick, not with magma but greystone is quite thick and sometimes takes a bit of heat, I also like to know how stuff comes apart
Guest Diamond Tints
Must be a jock thing :dunno
Cause the sassenachs are too scared to heat them in, and are %&$# tinters LOL jk before anyone starts :zzz
Guest naughtydog
Must be a jock thing :bat
Cause the sassenachs are too scared to heat them in, and are %&$# tinters LOL jk before anyone starts :bat
Eh - jocky wilson - what u saying pal!!
Do you still use the same method you have told me about before( top secret) or are you doing something else these days?
Guest tint325i
is that the patented diamond tints "bake the death out of it until the back glass explodes" method?? (merc ML!!)
Guest Diamond Tints
Must be a jock thing :gasp
Cause the sassenachs are too scared to heat them in, and are %&$# tinters LOL jk before anyone starts :err
AHahaha, f'n hell Scott, you got some memory :nuts , I sh4t when that happened :mad Only time its ever happened to me !!!
Still doing same thing Nik :bat Got some of this elmers to try, Like a kind of pritt stick top kind of thing though?? Not sure if needs to be actual glue? or if this other elmers will work??
Need to come down to yours for few days Nik, Share some tips and tricks :bat If your lucky I'll buy you a happy meal, cause im a good c**t that way :gasp
