Pyramids Posted April 24, 2010 Report Share Posted April 24, 2010 I found a little trick that may be new to a few people. I always found it a bit aggrivating to get the gaskets to slide back in on 2010 f150's. A shot of white lithium grease in the gaskets channel where the locking teeth are makes em slide in like a hot knife thru butter. There are plenty of other vehicles it works on too. This post has been promoted to an article Link to comment
Guest scottydosnntkno Posted April 24, 2010 Report Share Posted April 24, 2010 why in the world would you pull gaskets on a f150? Link to comment
Guest Scottsfire Posted April 24, 2010 Report Share Posted April 24, 2010 why in the world would you pull gaskets on a f150? I know you like the back of my hand! When I saw this I thought to myself, wonder what Scotty's going to do with this......cause I remembered you telling me how easy these are..ha ! Cheers mate! Link to comment
addicted to tint Posted April 24, 2010 Report Share Posted April 24, 2010 why in the world would you pull gaskets on a f150? Cause when you can yank em you can drop the film onto the glass and into place with zero obstructions on either side or the bottom as well as no fingertips whatsoever on the film. Fact is it this greatly reduces the chance for a random "spec" or any need for heating areas with gun once film is squeegeed and in place. So generally cleaner/easier but not a requirement to get it done. We all know you don't pull gaskets and never get specs or have to use any heat and have it all including life figured out. Link to comment
Guest gabe Posted April 24, 2010 Report Share Posted April 24, 2010 why in the world would you pull gaskets on a f150? Because it take 2 seconds and film won't peel from the bottom like someones 350z. Less chance of customer some backs. Link to comment
Guest GreenCove Posted April 24, 2010 Report Share Posted April 24, 2010 I found a little trick that may be new to a few people. I always found it a bit aggrivating to get the gaskets to slide back in on 2010 f150's. A shot of white lithium grease in the gaskets channel where the locking teeth are makes em slide in like a hot knife thru butter. There are plenty of other vehicles it works on too. works good I normally use wd40...def. makes it easier Link to comment
TintJunkie Posted April 25, 2010 Report Share Posted April 25, 2010 I spray the channel with my soap solution. Do you have to pull any screws to get the gasket out? I think I will start pulling the gaskets if they are easy to get out. Link to comment
Guest scottydosnntkno Posted April 25, 2010 Report Share Posted April 25, 2010 why in the world would you pull gaskets on a f150? Cause when you can yank em you can drop the film onto the glass and into place with zero obstructions on either side or the bottom as well as no fingertips whatsoever on the film. Fact is it this greatly reduces the chance for a random "spec" or any need for heating areas with gun once film is squeegeed and in place. So generally cleaner/easier but not a requirement to get it done. We all know you don't pull gaskets and never get specs or have to use any heat and have it all including life figured out. I've said numerous times on here that I snap all my doors, which a f150 hardly needs that. If you install without shrinking and squegee it out, you get 2 medium/small fingers, and thats it. Give it two seconds of snap, and your done. ford gaskets are so loose its not worth pulling them out. Link to comment
Guest gabe Posted April 28, 2010 Report Share Posted April 28, 2010 I pull the rubbers every time pull top of panel grab rubber done. Job done right Link to comment
Guest 515tinter Posted April 28, 2010 Report Share Posted April 28, 2010 I pull the rubbers every time pull top of panel grab rubber done. Job done right Link to comment
