how to get to the bottom of rear windscreen when its really tight
Guest james#70
Guest james#70
Did one today, still fairly new to tinting, mainly only tinted hatchback cars, but had a bmw in today and at the bottom of rear screen was so tight between glass and shelf. How do you guys do it, is there any better toold I need, extended squeeguee?
many thanks
Guest tint325i
what bmw is it? its only really the e46 3 series that can be tricky I think, most of the newer ones are easy enough to access the bottom of the screen, you can have the rear deck out an e39 in about 30 seconds flat!! then you can tint over brakelight, I had the deck out of mine yesterday to access top shock mount, its all clips, then an 8mm nut to remove brakelight
