Buying Plotter Tomorrrow Need advice
Guest WFWB
Guest scottydosnntkno
I cant decide between these 3. Graphtec 5000, ANA, Q series . What should I go with? Also what op system? Need Help!!! :bingo
vinyl express Q series? its a rebadged graphtec 8000, so I would pick that of the three.
Go with the Anagraph. It is the only plotter I've seen that does not leave track marks on the film.. It will also allow you to adjust the pressure by 1/10th incriments, and also has a quick release for the blade. Grapthec's do not, and makes changing a blade a pain in the arse!
my plotter to change the blade you flip the little level, pull out the holder, push the spring loaded bar on the end, grab out the old one and put the new one back in magnetically. Takes 5 seconds start to finish?
