dgmt321 Posted May 5, 2010 Report Share Posted May 5, 2010 Should I get the blue conqueror or the original? Whats better for cleaning? Link to comment Share on other sites More sharing options...
PJF Posted May 5, 2010 Report Share Posted May 5, 2010 Should I get the blue conqueror or the original? Whats better for cleaning? Go with the original with the yellow blade. The blade is more flexible making it better for a cleaning tool. Link to comment Share on other sites More sharing options...
Guest 515tinter Posted May 5, 2010 Report Share Posted May 5, 2010 Should I get the blue conqueror or the original? Whats better for cleaning? Go with the original with the yellow blade. The blade is more flexible making it better for a cleaning tool. the one with the blue blade is more stiff Link to comment Share on other sites More sharing options...
TINTZEUS Posted May 5, 2010 Report Share Posted May 5, 2010 I'v never seen the blue blade. I like my yellow and use it maybe twice a year. I have 4 or 6 of em. So that should last me for some time. Link to comment Share on other sites More sharing options...
dgmt321 Posted May 6, 2010 Author Report Share Posted May 6, 2010 is the blade molded or glued onto the body for the conquerer Link to comment Share on other sites More sharing options...
Guest GreenCove Posted May 6, 2010 Report Share Posted May 6, 2010 12" black and white with an angle cut on both sides works better Link to comment Share on other sites More sharing options...
PJF Posted May 6, 2010 Report Share Posted May 6, 2010 is the blade molded or glued onto the body for the conquerer Molded, just like the new original Conqueror is. If you are getting any that are still glued, your supplier has very old stock. Link to comment Share on other sites More sharing options...
blade Posted May 6, 2010 Report Share Posted May 6, 2010 I've never found a decent reason to even use a conqueror Link to comment Share on other sites More sharing options...
micro-edge Posted May 6, 2010 Report Share Posted May 6, 2010 I've never found a decent reason to even use a conqueror Me either, sorriest tool I own, it hasent even got me out of a jam one time yet Link to comment Share on other sites More sharing options...
VIP tint + glass Posted May 6, 2010 Report Share Posted May 6, 2010 I've never found a decent reason to even use a conqueror not even the rear corners of the older altimas back glass, and the newer c300 back glass? Link to comment Share on other sites More sharing options...
