precisioncut wish list
watchdaride
Been asking Precisioncut for a few features to add on there program
1-- On the page where you adjust the sunstrip have like a grid say 5" apart so you can measure the width off the sunstrip .
2- they need some basic commercial trucks like hino freightliner etc
3- on the rear doors put like a small bump on the bottom of the passenger door to easily tell the difference on those square doors.
4- Be able to make lettering arc into a sunstrip template.
other PP users add there feature request .
Lets all write an email asking them to add some of these features on .
I'd like to be able to open different designs or vehicles and have them stay in the viewing window or the cut window. computercut was great with how they did it. they had the arc feature too. precision cut needs alot of work to be more user-friendly. atleast the patterns are good though. :bingo
Can you move the patterns around on PC to better fit the size of material you are working with? I use FirstCut and I am able to rotate, stretch, move, and delete any extra cuts (like button cuts for ext cab windows). It also keeps all viewed templates open so if I am cutting multiple models of vehicles, and all are getting 20% on the bg, and 35% on the doors, I can first cut the bgs, and then after changing films, I can easily click on the open templates and cut the other patterns without having to reload each pattern again. Hope that made sense.
I wish I could use some other softwares to see how FC compares. My biggest complaint is there arent many visor strips. I am told it is because they would have to cut so many different sizes because of different laws per state. However, since I can change the size, I dont see how it makes sense.
yes you can do all of that, except the templates work on a system of tables, so like table 1 I have BG and vents to cut in 20, table 2 back doors, table 3 front doors. You have a little drop down to select a table within the open pattern.
Look in the upper right where it says table, you just swap between the patterns on the cutting table with that drop down
So it doesnt show all the patterns in one window? If thats the case, it would seem like a pain to cut a four dr with all the same shade.
    2. 7
    6. 11
    7. 11
