2 layers of limo
Guest Alcala
i have a bronco i use to go to desert races out here in the valley and mexico. i have always done the rear section with 2 layers of limo but it enhances the color of film from inside looking out. Looks too brownish or redish. anyone recommend a film brand/type i can use that keeps the same look as laying a single layer?
right now i have ewf tb5%. with the desert sun beating on you at 117 degrees double 5% almost doesnt cut it.
That would be because you are not really gaining that much extra heat rejection from a second layer of 5% film. If you want heat rejection try a different film set up....
More like that window is getting so hot its radiating more heat inside the car than it's blocking. I imagine several square feet of something absorbing massive amounts of solar energy can heat something that is only a few cubic feet very well. You would probably be better replacing the film with something reflective if legality isn't a concern
Having a "black window" using 5% X 2 is somewhat like a black body effect. If you remember in physics class. It will just attract more heat. Where having a metallic/reflective film will simply reflect the heat/light.
Go with HP film...
Guest Tintbds
Go with HP film...
Yep, Super is correct about metallic vs dye film
      Peanut Killer
      Experienced Tint Installer Needed Immediately - Birmingham, AL
    3. 7
      Peanut Killer
    4. 6
      Great to be back to the best tint forum ever
      Ppf installer $200k annually
    6. 0
      Hiring A Flat Glass Installer
    7. 3
      OG tinter
