Suntek
Guest TintChattanooga
Hi its been awhile since i have been on here. in my absence i have been tinting like crazy now that business has died back down i have an issue with suntek arcitecual<-sp?
i did a home with 2 sets of windows french panes in side and a set of storm windows outside. The custy did not like the french pane price so the storm windows were tinted
product used was suntek syds35 and i would tint one and bump it out looking great, then replace it on to the next one by the time i finished a set i noticed the corners were peeling up again
my question is why any help would be great.
I've been using minimal slip, makes it a little tougher to line it up where you want on the glass but she ain't curling much anymore...
Same here, I dropped the ammt of slip down to about 30% of what we normally use and it helped a bit. Like you said it just makes it more difficult to align where you want it
Thanks to all and i will drop the amount of slip down ......(i do use alot)
Also i do use elmers clear clue school gel to help with the dot matrix on some cars.
I.E. Mustangs
Guest tintjam65
Keep a small tube of clear acrylic adhesive caulk and when the corner is suspect, put a small dab in the corner to 'hold' the film down. Clear caulk will go unnoticed once cured.
      OG tinter
    2. 4
      Peanut Killer
    3. 4
      Peanut Killer
    4. 4
      Peanut Killer
      OG tinter
    6. 3
      OG tinter
      Peanut Killer
    8. 0
    9. 6
      Tack Solution When Vinyl won't lay flat
