Broken Rear Wiper? Customer Says Yes
finishlineautosports
I would explain that the wiper arm is held on by a 10mm nut. In order for the arm to fall completly off the vehicle someone would have to unsnap the plastic cover and remove the nut completly..
If you did not remove the arm and the part is inexpensive either just offer to replace it or split the cost of replacement with the customer.. just to maintain good cust. relations...
There is NO WAY you made the arm 'fall off' the vehicle by pulling it back a touch... they are spring loaded to keep pressure aginst the glass... PLUS they are designed to pull back for blade replacement.
  • Replies 29
Guest scottydosnntkno
i don't know about that particular car, but many cars that plastic piece either swings towards the arm, not away from it, or just pops off all the way. So neither of those would help. Like the infinit ex35 i did today, the cover just pops all the way off, and even with that off you can only lift the wiper a little bit
Here is the link for the wiper arm removal tool.
http://www.tools-plus.com/lisle-54150.html
i got 2, the pictured one; and the new spring loaded ones.
sounds to me like the wiper that has a tiny leer u pull out when u lift it up an inch. when the levers lifted the arm slides right off. those are normally on american cars only. wait its a vibe right?
    2. 7
    6. 11
    7. 11
