dvd player trouble
Guest tintec
did a regular customers vw golf today,he wanted a sun strip also job done no problems,hes on the phone a few hours later sayin his aftermarket jvc dvd player remote will not work and he cant fast foward songs on a cd,i know myself i havent touched or got it wet,so i told him to leave it a day or 2 to see if it starts goin again,anyone know what this might be guys :dunno
Guest tint325i
remote needs batteries
stand your ground on this one mate, Ive had people try stuff like this, i have a simple rule, if i break it i pay for it, if i didn't you can kiss my a##, i would seriously doubt you have damaged an in-dash player, different if it was a rear mounted one in a RR or X5 etc, no way your at fault here
coincidences happen, i had a guy come up and code in a key on a van last week, after he had done it the van wouldn't switch off, turned out to be a sticky ignition relay, just a fluke it happened after the key coding
these thing happen
these thing happen
yea mate its playing fine,the touch screen is working fine,remote wont work and the clock keeps resetting itself every time its switched off,i had ignition on alrite to put windows up and down but that was it,i clipped screen part out and showed him behind where there was absolutley no traces of water or moisture,hes ringing me back monday,yea probably chancing his arm :poke
Guest naughtydog
If the clock keeps resetting, there may be no permanent supply to the unit, this is what stores radio stations and clock etc...it may also power the remote side?
This is true, red and yellow wires are the constant & ignition hot wires. Some radios have in-line fuses on these. It could be the fuse. :cool
      OG tinter
    2. 4
      Peanut Killer
    3. 4
      Peanut Killer
    4. 4
      Peanut Killer
      OG tinter
    6. 3
      OG tinter
      Peanut Killer
    8. 0
    9. 6
      Tack Solution When Vinyl won't lay flat
