2011 Acura TSX Wagon
ljr1977
remove upper trim (pic shows on the bottom)
under trim is one nut and the plug for the brake and the water sprayer, there is also a screw and a bolt on either side...total count of five..all are a 10mm
the wing is still held on by four pressure clips that are seen in the picture and are white and have black square pads around the clips..
hope this helps..i noticed this car is not on computercut yet and im mailing the patterns off and they should be up next week...as far as the wing removal it should be a must for people that hand cut. there is no room to fit a knife, so removal is a must...
pic of the 2011 Acura TSX wagon with 30% on the front and 15% threw out the rest of the car..
the clips is what had me scared at first, once i looked threw the backside i could barely see the clips, so that made just pull up one side the swapped sides and pulled up on then it was free to remove..scary for the first one ive done...thanks guys just wanted to share...
Guest TintWhips
Good work :cool
    2. 7
    6. 11
    7. 11
