03 G35 Sedan, Thank God for the Bulldozer
FBO
I wish ever car was this easy to tint. The third brake light is close to the window, but couple pushes with the Bulldozer and it was all good. I removed the quarter windows. One philips screw on top, right under the weather strip. Two 10mm bolts holding the D-bar, take those out and push the D-bar forward with the window being all the way down. Take your time, and pull the Quarter window out.
Door panels are stupid easy to pull. One philips/10mm bolt where the Door Lever is, and two 10mm bolts behind the trim, or handle.
Better tip...don't remove any window or door panel.ever
Maybe someday, but right now i'm still in the learning process. Right after the G35, i tinted a 04 TL and did the same thing. Takes about 5 Minutes to remove the door panel, and the 1/4 window. Then i installed Felt on the seals.
Guest tintpro2007
Removing door panels is acceptable with some cars IMO, but removing windows is not. There isn't any window out there you can't do with it still installed. All your doing by taking window's out is running the risk of breaking it, or something else in the process and costing yourself money... :twocents
    2. 6
    4. 6
    6. 11
    7. 11
