Trick window on 2011 Hyundai Genesis
Guest arcwindowtinting
Cars with a window that drop's upon opening have been around for years. They all use to be controled by the latch.
If so open the door and use a small screw driver to act as the striker and close the latch. The window should move back up.
Other's are controled by a ground trigger switch, or door pin. Some will go back up by just unscrewing the pin switch from it's ground. Example the 350 Z.
While other are a positive wire that needs to be grounded through a switch to move backup. These can be somewhat tricky. Either find something to hold the switch in the closed position. Or disconnect the wire from the switch and bypass the switch with a jumper wire. Grounding the wire and causing the window to go backup to the closed position.
    2. 1
      Contravision
    4. 29
    6. 3
    7. 3
    8. 4
    9. 3
