2011 Chrysler 300
twotint
anyone done one yet, have one to do Saturday. looks easy enough and is in Film Designs already.
I did an 10' or 11' recently...no more brake light on bg. The rear deck appeared tight, but installed easily. I just made sure once the film slid in the bottom that i didn't slide it back up pulling contamination in.
The quarters look like they have a black surround, so shouldn't be a problem at all, which is nice if they're easy since they weren't there before :dunno
Have one coming soon, I'll check it out then
Not a horrible car to tint. Rear vents have a rubber seal towards the front and ceramic around the back. The rear roll ups move side to side a little so cut wide the fronts are tight since their laminated. The back glass has thick defroster lines and is tight in the lower outer corners but is reachable with a conquer.
