2010 Cadillac Escalade EXT
mustangdroptop96
Hey have a 2010 Escalade EXT, the back window looked easy enough but was kind of a pita with those little metal things on each side for the defrost but cut from the outside and cleaned up my cuts from the inside and that came out good, the driver passenger roll downs I'm not worried about I've tinted them before and aren't a big deal but the rear roll downs are where I'm running into trouble. The bottom has that body painted piece that curves and there are no rubbers on the outside, do you guys just mark it with a china crayon and cut on your cutting board or do you actually cut those on there? Any tips?
Dont cut around the curve. When i did my 07 i just line the bottom of your roll up where it needs to be then cut like normal then go to the peelin board and trim up what you need. I never cut the bottom side of roll ups. I always just line the factory edge up where it needs to be. Thats how i do it anyways. Are you pulling panels?
Hes right, b/c the inside doensn't curve like the outside, its straight. I cut the side thats not curved, then I trace the other side with a marker, except the portion that curves towards the bottom. Then I roll down the window far enough to cut the top as it curves down the side. Then you can match the top cut where it goes down the side to where you marked it.
    2. 2
      Mutoh cutter
    4. 2
    5. 1
    6. 4
