Susuki Swift 2nd generation 2011
Devil with bad attitude
New model out now, fairly simple but for those who pull trims.......
It's very easy to get the trim off, just 2 screws and the panel can be removed.
However at the top of each door it has a rubber insert and this is a bitch to pull out.
Instead of just being slotted into the metal groove, these rubbers have teeth!
Why they are so hard to pull up is because the strips anchor in behind metal indents (4 in the front and 3 in the rears) which therefore lock them into effectively a one way position.
A lot of effort is required to get them out with some swearing to boot but be careful not to bend them.
Rear 1/4 also has tight access.
One piece very easy in the rear and nice easy money once you've done one.
devil
