2011 Mazda 6
finishlineautosports
only thing you have to be careful of is the front door light. sometimes it can disconnect from the skin and it burn's through the plastic very bloody quick, also the door latch chords can disconnect from the skin and won't work... i run a check every door just to make sure with every mazda...but i do a mazda dealer so i fly threw them...great cars
No need to remove that much of the door panel. Just take out the screw behind the door handle and pop back the top of the door.
:spit Only make sure when reversing this, pull up high and hard or the gasket will tend to want to separate from the rest of the panel.
