venturesheild stains
Guest keepitcool
Guest keepitcool
has anyone else had a problem with rubbing alchohol staining this film? i sprayed rubbing alchhol on the surface of the material to clear up some imperfections and it stained the material badly. anyone else have this problem?
Guest keepitcool
Yes! I quit using venture a few months ago. Used to brag about the product all the time, but have had nothing but problems with it lately.
so what are you using now? and have you had the same problems? is there anything that will take the streaks out?
change films
Guest AccutintBellevue
Alot of times when film is stained by pure alcohol, you can use your heat gun to "cure" out the marks. Make sure to use direct heat and be careful! The film can be burned if you don't watch out. Good luck with your repair!
I like your avatar experience! :sm
I like your avatar experience! :lol
LOL! Yeah, I had one of my office guys set the profile up and I was gonna change it to reflect my actual age and experience. However, you must make 10 posts to be able to change anything in your profile. I'm 35 and have 11 years experience. My PPF business partner also has almost 13 years experience. Both of us are the original installers and designers from a company called StonGard. We have operated Accutint Bellevue since 2003. Hope that makes a little more sense. Have a good one!
StonGard? Hope you never had to use your health insurance! And by the way, using baby shampoo as a slip solution is not cheating. Only helicopter pilots think that way. :lol2
    d2iwindowfilm.com
      Independent Contractors needed for Security Film Project- Houston
    5. 4
      Mutoh Plotter
      Reveal Molding/Belt Moldings
    8. 4
