Tinting skylights
Guest tdmillet
Guest tdmillet
hey guys i have a job tomm with some large trapazoid skylights. And im going to do them myself so i was looking for some tips or tricks on peeling and applying the film. yes i have plenty of exp doing them but your never to old to learn. thanks dennis
I will almost always put the film up and precut the top and vertical edge, leave the bottom long, pull it off the glass, clean as usual, find somewhere to hang the film to remove liner and go about it as you normally would.
Guest tdmillet
thanks tom
I am a bit curious as to why wouldn't you go ahead and cut the
bottom since you already have it up? :dunno I am asking because I
do it the same way as you exept I precut all edges. Seems to
make for a cleaner install IMO.
bottom since you already have it up? :lol2 I am asking because I
Just because it gives m a bit more lee way when Im climbing a ladder with both hands full, if the film is going to drag on something , it is going to be the bottom when I position it into place and that is what will be cut off anyway. No right way no wrong, just works for me.
:spit I always leave the bottom long too, 90% of the homes I do have the stipple finish on the ceilings so I always kick up dust and it will either go on top or bottom. Gives a little breathing room. Plus slip solution seems to follow that tail and drip down to the floor instead of running down the frame and on the wall.
bottom since you already have it up? :spit I am asking because I
Not a bad idea, may have to try it for myself. :lol2
    d2iwindowfilm.com
      Independent Contractors needed for Security Film Project- Houston
    5. 4
      Mutoh Plotter
      Reveal Molding/Belt Moldings
    8. 4
