troubleshooting plotter
tintmeister
I have been cutting some small vinyl stickers for a customer and noticed that the cuts arnt so great, I figured if I got a new blade that the smaller fonts would come out better. I swapped the blades and tried adjusting the offset and force but with worse results then the previous blade. I then decided to switch back to the old blade and I still have these worse results. I can get the test cuts to a perfect square but the triangle in the middle is always messed up. Its like whenever there is an angle or curve, It gives me a squiggly, inconsistent cut. Does anyone have an idea of what this could be?
the stickers are 2.5 inches tall, and the smallest font on them is about 12-14 bold font. Im using an older version of flexi and I have a DGI omega plotter. Its got to be an issue with the plotter or blade set up, just not sure what.
any suggestions would be appreciated
