Technique is everything. Your side window preparation should go something like this: Spray the glass with soap solution. Razor blade the window to loosen contaminants. Spray the glass again. Scrub the window with a scouring sponge. Spray the glass again. WIPE THE WINDOW EDGES INCLUDING THE TOP OF THE GLASS with a clean rag or paper towel. Carefully squeegee the soapy water off the window in a pattern that zig zags sending the contaminated water downwards and overlaps by an inch to ensure correct coverage, and make sure your squeegee blade is leaning forwards at an angle so you don't leave a trail behind. Flush the vertical sides and bottom of the window to expel any residual dirty water. If you do this EXACTLY AS I SAY you will reduce the risk of getting crap under the film by 98% You can thank me later. -
^^^ great list of good habits. If your working on cars with rubber gaskets, roll down the windows first and spray them with SprayAway glass cleaner. Use a triangle card of some kind wrapped with a microfiber towel to scrub the dirt out and give it a couple squirts of water to flush it. Use the towel and triangle again when you're prepping the glass. Don't forget to scrub the top edge of the glass. -
It's important to prepare well, like taping felt to prevent the little particles from bleeding out, making sure to thoroughly clean the glass and sides, anywhere the film may touch. Also make sure the bottom flap is out of the way so that you can place the film with minimal manipulation. The more you have to move the film around to get it into position, the more chance you have of creasing it and or getting contamination. Also, make sure you touch the film adhesive side as little as possible. Having the glass ready so that you can handle the film well, without touching anything but the glass and not letting the film flop around or having to force it in somewhere. Another thing is that if there is any shrinking that needs to be done, do it before installing, as every time a finger pops up it brings a bit of dirt under with it. Work in a clean shop, mist the air around your work area right before pulling the liner also mitigates some of the airborne dust etc. -
Wassup everyone. I been practicing tinting on a few cars (mine and my family's) for about 2 months now and I feel like I've improved a lot since I first started. I do get these tiny bubbles around the edges sometimes. Can anyone give me any tips on how I can mitigate or eliminate these? (Ik its likely contamination but what can I do to improve my installation?) -
Beginner Tinter
Hello all, I’m fairly new to tinting and just been doing friends and families cars for practice. I am looking for help and guidance to help correct my errors. I keep getting these small scattered bubbles no matter what I change!? Thanks in advance. -
SIGNALS DEFENSE - EXPERIENCED WINDOW TINTERS NEEDED - COMMERCIAL
CONTACT - Austin Simpson 410-596-6412 Experienced Window Tinters Needed for Signals Defense. US Citizen Clean Background - Able to get onto government jobs Installing Signals Defense Films and Commercial Window Films Office - Owings Mills, Maryland Jobs Sites - Can stay local MD, DC, VA or travel Country/Worldwide -
The first picture appears to be similar to a 25%. Front of house? The second picture with 2 shades pulled down should get 25%, especially if facing West. The third picture should get 45%. The compromise is lesser privacy, while providing greater incoming light (already shaded from patio overhead). Small samples provided by the dealer don't give you a good sense of what the film will look like once installed. There is too much light streaming in around the sample (when taped to the glass), making the film look darker than what it will look like installed. The best and most accurate way to see what it will look like, viewing out, is to use the sample as quasi-sunglasses by wrapping it around your face and eyes (to the point of no light leaking in). Now, look toward the window(s). Viola`, there's your tinted view. As to the tax benefit, do check with a pro tax person just in case they no longer have that program. I've been retired for almost a decade now. -
Wow thank you for the comment about the tax advantage. I'll definitely have this noted for my taxes. And thank you for the recommendation for Madico Optivision. For $47 more, I would not mind going with them after what you said. On that Madico proposal, I've been going back and forth about the Front Bedroom. These windows NEED to have a mirror like finish and I'm between the 25 and 35. The 25 is definitely very mirrorlike, but I'm afraid it might be too much for a set of windows facing the street, so possibly the 35 would be better? What are your thoughts? Attaching a picture of the front windows that currently have this Kespen tint I bought off Amazon. Which of the 25 or 35 would be closest to this finish? I'm okay with doing 25 on the Master Bedroom though since it's in the back of the house and facing West. I don't have any neighbors directly behind me due to it being a greenspace where a pipeline runs underground. I've had the samples up and keep going back to look at them, but it's sometimes hard to tell. I don't have a sample of the 45 for the living room, but I think that's as high as it goes, so I'm fine with 45 to allow max amount of natural light through.
